Cannot remove key
130,000 MILES • 3.5L • 6 CYL • 4WD • AUTOMATIC
LYNN KING
My car starts and turns off, but can't remove key.
Mar 31, 2019 at 2:32 AM
SCGRANTURISMO
  • 4,897 POSTS
While doing a little research on your vehicle I came across this Technical Service Bulletin (TSB) for recalls being done for defective ignition switches. You might want to call your local Chevrolet dealership and see if your vehicle is one that is affected by this recall. I have included the entire TSB in the diagrams down below. Let us know how it turns out.
Thanks,
Alex
2CarPros
Mar 13, 2021 at 2:27 AM
LYNN KING
I had the ignition switch fixed and put the thing in the key on a recall.
  • 55,560 POSTS
So is the problem fixed or?
LYNN KING
it was the gearshift assembly and connecting wire.
  • 55,560 POSTS
The shift cable or?
