Keeps stalling until engine is warm
KEMOY28
  • 1987 TOYOTA CELICA
  • 2.0L
  • 4 CYL
  • FWD
  • MANUAL
  • 250,000 MILES
My car keeps stalling whenever I start it up, once the engine is cold or warm, whenever I start it I always have to rev it for like five minutes until it is warm before it will throttle without stalling. My cold start valve is working and my spark plugs are new, vacuum lines are fine, it will throttle fine once operating temperature is reached.
I have a lot of white smoke from the exhaust when I rev it or accelerate. How do I fix it?
Monday, April 25th, 2016 AT 7:01 PM
KEMOY28
  • 28 POSTS
Codes I got are, obd1 43 starter signal to ecu missing, 21 main oxygen sensor signal fault, but only comes up now and then.
Tuesday, April 26th, 2016 AT 7:30 AM
KEN L
  • MASTER CERTIFIED MECHANIC
  • 48,363 POSTS
It sounds like you have a blown head gasket which creates the white smoke and the oxygen sensor codes, Please check out this article to get more info on how to check for that.
This would also make it stall when cold, please check it out and get back to me.
Tuesday, April 26th, 2016 AT 3:51 PM
