Keeps shutting off while driving?
280,000 MILES • 5.3L • V8 • 2WD • AUTOMATIC
MELISSA WINDSOR
It starts and will go for a bit then shuts off while driving, replaced fuel filter, can hear pump come on, checked lines for leaks, primed it by turning off and on several times. Need Ask matrix for the wiring on the motor.
Feb 4, 2025 at 8:11 AM
  • 55,710 POSTS
Hello Melissa,
This is typical when the crankshaft sensor starts to go out, here is a video to help you replace it which should fix the problem, also do you have a check engine light on? If so, we should run the codes to see what codes are stored.
https://www.youtube.com/watch?v=-Ib3Lkde3Wo&t
Please go over this guide as well to retrieve the codes:
This guide shows you the other possibilities for the stalling:
https://www.2carpros.com/articles/engine-stalls
Please go over these guides and get back to us.
Feb 5, 2025 at 12:57 AM
