Keeps Overheating?
275,876 MILES • 2.2L • 4 CYL • 2WD • AUTOMATIC
TINAMCABEE
I have replaced the water pump, thermostat, radiator, radiator hoses, plugs, wires, changed oil, flushed radiator, and hoses, and replaced coolant fan. Still overheating and now heater is blowing cold air. Why is it overheating?
Jun 16, 2023 at 9:06 AM
  • 110,248 POSTS
If the heater isn't working, chances are it is low on coolant or there is an air lock in the system preventing coolant from reaching the heater core.
It sounds like you have done everything possible. Have you checked for a failed head gasket? Do me a favor, take a look through this link, and check what you are comfortable with:
In addition, let me know if the vehicle overheats at highway speeds and if the cooling fan is working.
Jun 16, 2023 at 1:53 PM
