Keeps Stalling?
1,155,461 MILES • 3.3L • AUTOMATIC
JANELLE BONDERER
So I have a 1990 Oldsmobile Cutlass Ciera and it keeps dieing on me. It’s hard to explain tho so bear with me…. So when I’m in park the idle is fine no issues. Once I start driving and have to slow down AT ALL it will just die. Sometimes I can put into N and it will start back up. Other times I have to put it in park in order to start it back up. It’s not that alternator, nor the battery. It’s not the fuel filter, I replaced it last night. I’ve cleaned out the throttle body, worked for about 5-10min, then I go to leave again and it starts same thing over again. It acts like it’s not getting something but can’t for the life of me think what it is. PLEASE HELP ME ME CAR GURU!!!! lol
Oct 3, 2026 at 6:55 PM
What to check next
Diagnostic guidance. Suggested checks and possible repairs are separate from the owner's reported results.
Start by separating two symptoms: does the starter turn the engine normally when it will not restart, or does the engine not turn at all? Record that distinction and whether the problem occurs only when slowing in gear. That gives the technician a useful direction before any more parts are purchased. If the engine turns normally but will not start, have spark and fuel pressure checked during the failure, using the specifications for this engine. Low fuel pressure alone does not prove the pump is bad; its electrical supply and ground also need checking. Repair the fault identified by those tests and verify reliable restarting. If the engine idles normally in Park but stalls as the vehicle comes to a stop in gear, ask the technician to check whether the torque-converter clutch releases correctly, alongside the engine's idle-control operation. The discussion raised this possibility but did not establish it. Avoid unplugging transmission wiring for a road test. Because the vehicle stalls in traffic, arrange diagnosis without continuing to drive it. You already have a useful starting point: clearly identifying the restart behavior will help separate a starting-system issue from an engine-running or transmission-load problem.
Guidance references and applicability
Original discussion, supplied source snapshot: https://2carpros.com/questions/keeps-dieing--1713500 Documents the stalling pattern, ambiguous restart description, and unconfirmed transmission and fuel-system suggestions. Delphi, How to Perform a Voltage Drop Test (consulted 2026-10-11): https://www.delphiautoparts.com/resource-center/article/how-to-perform-a-voltage-drop-test Supports checking fuel-pump supply and ground before condemning a pump from low output. This is a general principle, not an engine-specific pressure specification. The proposed diagnostic branches are reasoning from the reported symptoms. Exact 1990 Oldsmobile service procedures and test specifications have not been independently verified here. No repair is confirmed; manufacturer service information is required for component testing.
Read the replies · Discussion summary and reported outcome
KRAKENAUTO
  • 113 POSTS
I'm curious if your transmission is not coming out of lockup when you stop. Pretty easy way to tell is to unplug the connector going to the transmission and drive it. If it is that, then it will not stall on you like that. Essentially if it is that problem it acts like a manual transmission coming to a stop without pressing the clutch (hence stall out).
I'll see if I locate a photo, my service info is not accessible at the moment but I will update with a photo if no one else has by then shortly.
Oct 3, 2026 at 7:54 PM
JANELLE BONDERER
It’s an automatic transmission. People keep telling me it’s my fuel pump. I’m so over stressed with this car. I can’t get to work because of it.
Oct 3, 2026 at 7:56 PM
KRAKENAUTO
  • 113 POSTS
Yes it's an automatic transmission, but when lock out is acting up it will act like a manual if it's not working correctly, the same as if you had a manual transmission and forgot to press the clutch in.
Oct 3, 2026 at 8:13 PM
JANELLE BONDERER
How do I fix that???
Oct 3, 2026 at 8:15 PM
KRAKENAUTO
  • 113 POSTS
We would have to determine if it's a bad switch or torque converter, both would be in the transmission itself.
Oct 3, 2026 at 8:17 PM
JANELLE BONDERER
It’s like it won’t get gas to the engine. It acts like it wants to start but just can’t crank over
Oct 3, 2026 at 8:20 PM
KRAKENAUTO
  • 113 POSTS
Ok that is not what your original question states. You stated it starts fine when in Park and is all good till you slow down then it dies. You can then put it into N or Park and most of the time get it to restart. Normally if you have a bad fuel pump it's not gonna restart immediately.
It is possible you have a bad fuel pressure regulator if it starts up fine but doesn't hold pressure. You can test this a couple ways:
Locate the fuel pressure regulator positioned on the fuel rail near the intake manifold. Pull the small rubber vacuum hose off the top of the regulator. If raw gas pours out, the internal diaphragm is bad and the regulator needs replaced.
Another method is to fid the test port (Schrader valve) on the fuel rail. Attach a fuel pressure test gauge securely to the valve. Turn the key to the on position so it primes the fuel system. It should have between 40-47 psi of fuel pressure. If that looks good, start it up and look at the pressure, it should not drop much more that 10 psi once it's idling.
A third method to test is with the engine idling and the fuel pressure gauge attached, pull the vacuum hose off the regulator and plug the hose end with your finger. If the fuel pressure immediately jumps back up, it's good. If it doesn't change when you remove the vacuum hose, then the regulator is stuck.
Oct 4, 2026 at 12:07 PM
Discussion summary
Keeps Stalling?
The owner of a 1990 Oldsmobile Cutlass Ciera reported normal idling in Park but stalling when slowing down while driving. The engine could sometimes be restarted in Neutral or Park. Replacing the fuel filter did not resolve the problem, and throttle-body cleaning helped only briefly. A contributor raised the possibility of the torque-converter clutch remaining engaged. After the owner added a less clear description of difficulty restarting, the discussion also considered fuel-pressure regulation and suggested fuel-system checks.
Reported outcome: No results from the proposed transmission or fuel-system checks were reported, and no successful repair was confirmed.
The later description does not clearly distinguish an engine that will not crank from one that cranks but will not start. Neither a torque-converter-clutch fault nor a fuel-system fault was established.
Read the original discussion
