keeps blowing fuses for the four wheel drive
80,000 MILES • 4.0L • 6 CYL • 4WD • AUTOMATIC
HOMER NICHOLSON
when it works it is fine. after a couple days of using the four wheel drive in the morning when I turn on the ignition switch it blows the fuse and it is not in four wheel drive.
Mar 15, 2017 at 7:49 AM
HMAC300
  • 48,601 POSTS
scan for codes first then check wiring for broken/chafed etc. it may hitting on body or frame and or the shifter motor may be bad on transfer-case.
Mar 16, 2017 at 12:22 AM
