stilling keeps stalling,keeps cutting off. Replaced the PCV value still got error P0442.
Jun 26, 2017 at 12:28 AM
✓Experienced Mechanic
Yes this is a EVAP code has nothing to do with the PCV valve. Check you gas cap first and then check the EVAP hoses of leak from the engine to the tank.
Here is a guide that will help you get the problem fixed.
