k9 bcm x6/k73 telematics comm x2?
130,320 MILES • 2.0L • 4 CYL • 2WD
JAKNIYAH
  • 31 POSTS
I recently did an ohms test because the system was reading 120ohms. i disconnected the k73 x2 connector telematic module because it stop reading 120ohms, but still had an open circuit. I did the same test on the bcm module, i disconnected the x6 connector and the ohms read zero. My question is: is the bcm bad, or the path(wiring) to the telematic comm bad?
Jan 11, 2026 at 11:26 AM
  • 55,782 POSTS
I am not sure what you are saying here? Why are you testing the OHM readings? Did you do a CAN scan to check for codes and if so what are they?
If you have not preformed the scan here is how it is done.
CAN SCAN - https://youtu.be/u-4syLc-ifQ
The codes will tell us the direction we need to go in instead of testing random wiring.
Jan 12, 2026 at 4:17 AM
