My cav 1998 2.2L 5speed manual does not run,only cranks.I replaced CPS and ICM but still the same,and no communication with OBD-2 scanner.i've decided to replaced the PCM.After replacing with a used PCM,the car now start but dies after 2 sec..no anti-theft indication,though the bulb is ok.Tried relearn method and also by-pass resistor method.I replaced the fuel filter before the first problem.All fuses and relays are ok.Ignition switch/lock cylinder was found ok also.Checked vacuum lines for MAP and found good.Serial data wire to PCM from Instrument Panel Cluster is also good.What might be the problem.Please help..I'm getting crazy.Dealer/Service centers here in Saudi Arabia are not accepting to repair it since they are below 2000 year model.You're expertise and advise are my only hope.Thank u and more power.
Mar 20, 2014 at 2:00 AM
