I replaced the fuel pump after diagnosing it and now all it wants to do is click. It will not try to turn over. Any suggestions?
Aug 28, 2017 at 5:18 AM
STEVE W.
✓Experienced Mechanic
Double check that the battery cables are not corroded inside the battery terminals or at the other end. I've seen them go from good to bad from simply moving the cable while something on the vehicle is serviced.
OR do you mean the pump isn't turning over, In that case you may want to check the pump control module.
