code p0700
107,000 MILES • AUTOMATIC
JESSRAE25
It had code p0700 first then all other codes point to the transmission control module failing. We just replaced the computer module (pcm) four days ago. i know they are linked for sure could one cause the other to fail? Or a loose connection or something? We just think it is odd we just replaced the computer module days ago now the transmission module is failing?
Aug 7, 2016 at 12:37 PM
SATURNTECH9
  • 30,868 POSTS
I have no idea why you replaced the pcm? the pcm would be the power-train control module meaning that would be the engine control module and the transmission control all in one.
Aug 7, 2016 at 12:50 PM
JESSICA RAE
because the car died a few weeks ago we replaced battery and all the fuses, still did not work. had it towed and diagnosed at an auto repair shop and they said we needed a new computer module we had that replaced. the car worked great for four days, now the car is not drive-able it clicks into gear but does not move, it will reverse but it wont drive , check engine light was read all codes pointing to the transmission problems, transmission control module. i am just wondering are they linked? they do work together? I do not think it is a coincidence that we just replaced one computer module four days later the other goes out? could there be a loose connection or something?
Aug 8, 2016 at 5:04 AM
SATURNTECH9
  • 30,868 POSTS
They share inputs etc. to each other for shifting etc .So what are the exact code numbers not code descriptions you have? I am flying blind here.. lol.
Aug 8, 2016 at 7:54 AM
