Just replaced a broken exhaust flex pipe
2005 FORD FIVE HUNDRED
185,000 MILES • 2WD • AUTOMATIC
MATTHEW VOGT
Car has no power.
Will not shift out of 3rd gear.
Started on the way home from the exhaust repair.
Sep 15, 2021 at 5:30 AM
SQM
  • 6,383 POSTS
Did this just happened all of a sudden and did not have any symptoms before?
If the vehicle has very little power and unable to shift to higher gears, it could be due to the vehicle is in limp mode/low power mode.
There could be several factors of why the vehicle can go to limp mode.
Please have a look at these articles for some helpful information:
https://www.2carpros.com/articles/reduced-power-limp-mode
https://www.2carpros.com/articles/engine-has-low-power-output
Typically with the limp mode the vehicle will have sluggish acceleration and could also make it difficult for the transmission to shift.
Many times when the vehicle is in low power mode, the check engine light gets illuminated. Is your check engine light on?
Sep 15, 2021 at 4:23 PM
