Just put in a new ignition but will not start
164,000 MILES • 1.7L • 4 CYL • 2WD
SHAZZYDOO
Starter motor, battery, fuel all fine. Wynns over just won't. Kicks over when spray starting fluid in it just won't idle.
Jun 30, 2021 at 3:01 PM
  • 110,248 POSTS
If it starts with starting fluid, then there is a fuel-related problem. This model wasn't offered in the US in 1995, so I don't have the specifics as far as fuel pressure specifications. However, that is where I would start checking.
Here is a link that shows in general how it's checked:
Also, make sure there are no vacuum leaks that could be causing it to stall after starting.
Let me know what you find. I'll try my best to help.
Jul 1, 2021 at 2:53 PM
