Battery cable
51,000 MILES • 1.6L • 4 CYL • 2WD • AUTOMATIC
DAVIDCC
Sir, at battery positive terminal fixture 2 cables lead off; 1 leads to starter motor. Where does other cable lead? Thank you
Jun 20, 2020 at 1:20 AM
Great question. It indirectly leads to the alternator but directly leads to the fuse box that I circled in the attached wiring diagram. As you can see the other wire leads to the starter as you mentioned.
Let us know if you need more info. Thanks
Jun 20, 2020 at 1:48 AM
