After replacing the rack and pinion, CV axles, ball joints and wheel bearings there is a random high pitch screech?
130,800 MILES • 2.4L • 4 CYL • 2WD • AUTOMATIC
DASHANIQ14
I just replaced my rack and pinion, my CV axles, my ball joints and wheel bearings because they were very worn. When I drive, I hear a random high pitch screech (not squeal). I also hear scraping when I turn left and sometimes right. When I get up to 65mph and more my car starts shaking a lot and it begins to feel like my steering wheel is light and loose. Before all this my car would just randomly shake primarily on the left-hand side and when I would get on the highway at about 70 it would shake and then it would stop shaking when I hit 80. I just spent a whole lot of money trying to fix it and the car seems like it’s worse than before. I tried to add a video so you can hear the sounds it’s making. I’m not an expert but I know that isn’t right. What is the problem?
Jul 15, 2023 at 11:08 PM
DASHANIQ14
This is one of the videos. You may hear better with headphones on.
Jul 15, 2023 at 11:15 PM
  • 110,248 POSTS
I did hear a noise. To me, it sounds like a bearing. Does it change in volume or intensity when turning? Did you have any problems when installing the new wheel bearings?
Did you have the vehicle aligned?
Jul 16, 2023 at 4:22 AM
