Will all the brake fluid leak out if one of the chambers is leaking?
50,000 MILES • 1.0L • 4 CYL • 2WD • AUTOMATIC
DAVE213
  • 38 POSTS
if a dual circuit system had a leak on one of its circuits, does the brake fluid all leak out after repeated pumping?
Jan 11, 2021 at 11:55 AM
Good evening,
The answer is no. Only the chamber with the leak will drain and the other will remain at its level.
https://www.2carpros.com/articles/how-to-bleed-or-flush-a-car-brake-system
https://www.2carpros.com/articles/brake-pedal-goes-to-the-floor
I attached the diagram of the system for you when you are looking for leaks.
Jan 11, 2021 at 12:21 PM
DAVE213
  • 38 POSTS
But will the brakes still be firm or not? And how long can someone drive with the spare circuit?
Jan 11, 2021 at 4:07 PM
No, the pedal will be half at best and the stopping distance will be greatly increased.
I would not drive it that way at all. I would get it fixed ASAP.
Jan 11, 2021 at 7:24 PM
DAVE213
  • 38 POSTS
So no floor touching.
I think it gives the same symptoms of failing master cylinder if i am not wrong.
Well, how far can you go if one of the circuit is broken?
Jan 11, 2021 at 7:26 PM
Again, I would not drive it with the pedal that low. It is an extreme safety hazard and needs to be repaired.
I would not drive more than the distance to a repair shop.
Jan 11, 2021 at 7:38 PM
DAVE213
  • 38 POSTS
Yes, i know usually in single circuit system ince the fluid is over the brakes stop working.
Does it take the same time for the dual system to stop working or take longer?
Jan 11, 2021 at 7:42 PM
When you have only one portion working, the pedal reaction time and distance for stopping are greatly increased as I stated before.
Jan 11, 2021 at 7:49 PM
DAVE213
  • 38 POSTS
Thanks Roy.
Jan 11, 2021 at 7:54 PM
You are welcome.
Always glad to help.
Jan 11, 2021 at 8:00 PM
