Rough idle when started. Dies as soon as I let offthe gas.
May 5, 2016 at 5:06 PM
HMAC300
✓Experienced Mechanic
try cleaning throttle plate on both sides and iac hole with choke cleaner then check fuel pressure with a gauge auto parts rent it.
May 6, 2016 at 12:06 AM
RENEE L
MEMBER
If you decide to check the fuel press yourself, here is a link to one of the articles from this site that explains and shows you how to the fuel pressures yourself.
