Jumpy engine
155,000 MILES • AUTOMATIC
JENIFER53677
Rough idle when started. Dies as soon as I let offthe gas.
May 5, 2016 at 5:06 PM
HMAC300
  • 48,601 POSTS
try cleaning throttle plate on both sides and iac hole with choke cleaner then check fuel pressure with a gauge auto parts rent it.
May 6, 2016 at 12:06 AM
RENEE L
  • 1,260 POSTS
If you decide to check the fuel press yourself, here is a link to one of the articles from this site that explains and shows you how to the fuel pressures yourself.
Please get back to us with your results so we can further assist you. Thank you for visiting 2CarPros.com.
May 6, 2016 at 6:23 AM
