Car turns off while coming to a stop
233,000 MILES • 2.4L • 4 CYL • 2WD
LORTEGA
  • 7 POSTS
Recently did a timing belt replacement. Was running good for about 3 weeks. My car is shutting off while driving.
Feb 14, 2020 at 3:20 PM
JIS001
  • 3,412 POSTS
There is a service bulletin to improve the idle quality which requires an ECM update and replacing the camshaft.
Engine/Engine Controls - Poor Idle Quality
Vehicle Powertrain Management Technical Service Bulletins Engine/Engine Controls - Poor Idle Quality
ENGINE/ENGINE CONTROLS - POOR IDLE QUALITY
No.: TSB-04-11-003
DATE: October, 2004
Model:
2004 Galant
SUBJECT:
POOR IDLE QUALITY
PURPOSE
For 2004 Galant MIVEC models with VINs after 4E107228 (Federal emissions) or 4E108924 (California emissions), idle quality can be improved by only adjusting the valve clearances as described in TSB-04-11-004. Camshaft replacement and PCM reprogramming will not improve idle quality on vehicles with VINs after 4E107228 (Federal emissions) or 4E108924 (California emissions).
On affected vehicles (VINs before 4E107228 (Federal emissions) or 4E108924 (California emissions) that exhibit poor idle quality, idle quality can be improved by performing all of the following three repairs:
^ Install a new, improved camshaft listed in this bulletin.
^ Adjust the valve clearances as described in this bulletin.
^ Reprogram the PCM as described in TSB-04-13-010.
AFFECTED VEHICLES
2004 Galant models equipped with 4G69 2.4L MIVEC engine before the following VINs:
- VIN 4E107228 (Federal emissions)
- VIN 4E108924 (California emissions)
PROCEDURE
1.  Inspect the rear of the cylinder head for a punch mark with white paint.
    a.   If there is NO punch mark with white paint, go to Step 2 for camshaft replacement.
    b.   If there is a punch mark with white paint, go to Step 3 for valve clearance adjustment.
2.  Replace the camshaft, using the part listed in the PARTS INFORMATION section of this bulletin. The new camshaft has an "L" identification mark.
    Refer to Group 11 A in the 2004 Galant service manual for replacement procedures.
    IMPORTANT
       Replace the camshaft and reprogram the PCM only if the VIN is before 4E107228 (Federal emissions) or 4E108924 (California emissions).
a.   To identify the new camshaft for future servicing make a small punch mark at the rear of the cylinder head, then apply a white paint mark over the punch mark.
         Continue with Step 3 for valve clearance adjustment.
3.  Adjust the valve clearances to the following cold specifications:
    Intake: 0.11 mm (0.004 in.)
    Exhaust: 0.20 mm (0.008 in.)
4.  If the camshaft was replaced, reprogram the PCM as described in TSB~04-13-010.
Feb 14, 2020 at 4:35 PM
LORTEGA
  • 7 POSTS
My vin# comes after E108**** ( Cali. Emissions)
I got my car scanned by AutoZone. This is what they printed out.
I can't find any leaks on hoses.
So I check my o2 sensors. They look bad. Black and white.
Could that be the reason my car keeps shutting off?
Feb 18, 2020 at 9:03 AM
LORTEGA
  • 7 POSTS
Oh yeah. I found a half in. Bad wield on one pipes of my catalytic converter.
Feb 18, 2020 at 9:05 AM
JIS001
  • 3,412 POSTS
On your post you have your vehicle as a 4 cylinder? But your trouble codes say you have bank2 running too lean when you only have one bank? Do we have the correct information?
Feb 18, 2020 at 11:18 AM
LORTEGA
  • 7 POSTS
I thought so. I don't have my own reader. But I did check out my o2 sensors and they do look bad.
Feb 18, 2020 at 11:40 AM
JIS001
  • 3,412 POSTS
If this is a V6 then there is another bulletin for your fault code P0174 which requires an ECM reflash.
TSB No: TSB-05-13-005
Date: February, 2005
Model: 2004 Galant 3.8L V6
Subject:
PCM reprogramming FOR DTC P0174 (2004 GALANT V6)
Purpose:
Incorrect PCM software parameters may cause the MIL to turn on and Diagnostic Trouble Code P0174 to set. To eliminate this condition, reprogram the PCM as described in this bulletin.
Feb 18, 2020 at 10:14 PM
