Jumper cables
173,000 MILES • 4 CYL • 2WD • MANUAL
BROKENEGGS
  • 198 POSTS
Is it okay to use jumper cables to start this car?
Sep 10, 2019 at 8:22 AM
BROKENEGGS
  • 198 POSTS
The battery went dead on this car while it was just sitting in yard over night. What do you think caused it?
Sep 10, 2019 at 8:26 AM
I feel like I am missing something with this question because I am not sure why you would not be able to use jumper cables. If the engine has a 12 volt battery system then you are fine jumping it with another 12 volt battery.
It is hard to say what caused a battery to drain overnight because any electrical load left on or coming on improperly will cause the battery to drain.
Here is a guide that walks through the basic and most common items:
https://www.2carpros.com/articles/car-battery-dead-overnight
If you don't find anything with these items, we will need to perform what is called a parasitic draw test. That is where you hook a meter in line between the negative cable and the negative battery post. Then when you find that you have a draw (10 milliamps or more) you start removing fuses until the draw drops to a normal level. Then you know what fuse caused it and that system is the issue. At that point it is either the component on that circuit or the wiring/switch/relay on that circuit.
Let me know what you find and we can go from there. Thanks
Sep 10, 2019 at 8:40 AM
BROKENEGGS
  • 198 POSTS
I have found out it is not the battery. The lights are too bright.
Sep 13, 2019 at 2:55 AM
Okay. Are you saying that the battery is not dead because the lights are bright?
If so, we should still test the battery because the light brightness is a little too subjective. Plus, they only need about 8-10 volts to appear bright but if that is the case, the starter may just click.
Let me know how else I can assist and I will be happy to provide it. Just tell me what the current issue is and we can work through it.
Sep 13, 2019 at 1:11 PM
BROKENEGGS
  • 198 POSTS
You are right , The battery was weak , I jump started it and it is fine now.
Sep 14, 2019 at 3:50 AM
Awesome. I would just let it idle for a little while but also start preparing to replace the battery. My wife's car did the same thing so it is just a matter of time before it will require replacement.
Thanks for the update and using 2CarPros. Please come back if you have other questions. Thanks
Sep 14, 2019 at 4:22 AM
BROKENEGGS
  • 198 POSTS
Thanks so much..
Sep 15, 2019 at 11:51 PM
