engine misfiring
106,000 MILES • 2.0L • 4 CYL • 2WD • MANUAL
READYRANGERS
  • 17 POSTS
I have a slight problem with my tsk model. When in sixth gear doing about fifty five mph the revs are about 1500 rpm, I get a juddering for a few seconds then it is fine. It is similar to being in to high a gear for the speed, it is okay if under that revs. As soon as it hits 1500 rpm it does it until about 1600 to 1700 rpm. would this be pointing to dual mass flywheel? It also is a tad rough at start up, i also seem to need to give it a bit more revs to reverse as if the brakes are sticking slightly. Could this be one thing causing all those problems?
Mar 7, 2017 at 5:08 PM
  • 55,694 POSTS
Hey,
Is the check engine light on and if so does it have any codes? Also have you changed the fuel filters recently?
Please let us know.
Best, Ken
Mar 10, 2017 at 3:53 AM
READYRANGERS
  • 17 POSTS
Hi ken. It is not putting on the light or showing faults. I just noticed predictive text kicked in, it is the 2.0l tdi I have.
Mar 13, 2017 at 5:11 AM
  • 55,694 POSTS
It sounds like it could be the mass air flow sensor, can you try cleaning it please here is a guide.
https://www.2carpros.com/articles/mass-air-flow-service
Best, Ken
Mar 13, 2017 at 5:15 AM
READYRANGERS
  • 17 POSTS
Thank you Ken. Will give this a try and report back.
Mar 13, 2017 at 5:34 AM
READYRANGERS
  • 17 POSTS
Morning Ken. A wee update on my problem. I put the car into get the timing belt done, the timing was off. I also have a new turbo as mine was leaking oil, the pick up pipe was partially blocked. Not got the car back yet to test it, just the service to get done today. If I get a chance to test it today I will let you know.
Thanks
Mar 16, 2017 at 6:59 PM
READYRANGERS
  • 17 POSTS
Everything done including mass airflow sensors, still doing it. I remember something else I noticed, it seems you need slightly more revs when starting to reverse. Would it be possible its the start of dual mass flywheel?
Mar 17, 2017 at 3:01 AM
READYRANGERS
  • 17 POSTS
I went out yesterday for a run in the car, It does it in 5th and 6th. If you are about 1500rpm and you put the boot down it misses anywhere between 1500 and 1800rpm, it just does it for a few seconds then it's fine. Anybody got any other ideas?
Thanks
Mar 19, 2017 at 5:13 PM
  • 55,694 POSTS
It could be the injector pump is starting to go out, I don't think it is the dual mass flywheel becasue all that does is help with engine vibration.
Can you take a video of the problem and post it to youtube then send us the link?
Best, Ken
Mar 22, 2017 at 4:50 AM
READYRANGERS
  • 17 POSTS
Another little update. Had it in today hooked up to vag-com, no faults coming up. Looked at injector etc, everything coming back as ok. He took the egr valve off, its all good. I remember the turbo pipe came off, it was doing the same thing but worse in all gears. Once the pipe was back on, it still done it in 5th/6th. The pipes were checked and all looked safe and sound. I did take a video this morning, you can't really see anything.
Mar 28, 2017 at 12:07 AM
READYRANGERS
  • 17 POSTS
I still have this problem. Both independent and vw have looked at it, nobody can get to the bottom of it. I am going try try a plug and play ecu, had something similar with a Audi I owned. I will update once I get round to it.
Jul 23, 2017 at 5:45 PM
  • 55,694 POSTS
Please let us know what happens, we are interested to see what it is.
Cheers, Ken
Jul 24, 2017 at 9:03 AM
READYRANGERS
  • 17 POSTS
I tried the ecu, still the same. Also since I posted, I changed inner and outer cv joints as one had play. Still the same and no fault codes, looks like I will just have to live with it.
Aug 15, 2017 at 4:32 PM
  • 55,694 POSTS
I am starting to lean toward the injector pump itself. Live with it for a while and see if it gets worse this will help tell us the pump is deteriorating and needs to be replaced. This is a common problem with diesel engines.
Aug 16, 2017 at 3:49 AM
READYRANGERS
  • 17 POSTS
Hi ken. I just found this post again. I never got to the bottom of my problem, I just live with it. I intend to sell the car as is, I tried a shot of a new rear fuel pump, never helped either. It has never got any worse, I am back to thinking about when the turbo pipe came off. It was doing the exact same thing but worse, am I missing a split or cracked pipe somewhere.
Thank you
Feb 2, 2018 at 5:18 PM
