Shift trouble
104,000 MILES • 2.7L • V6 • FWD • AUTOMATIC
JMANGA
Transmission is four speed automatic/manual. I can shift manually first through forth gear at any rpm, but in "D" auto position it will only shift to next gear at four thousand each. I hear these transmissions have a shift module, could this be the problem?
Dec 8, 2016 at 6:53 AM
HMAC300
  • 48,601 POSTS
all newer cars have a module have a transmission scan for codes because it may not be a module problem may be a valve body problem. also, check all fuses under hood as well.
Dec 8, 2016 at 10:38 PM
