Jimmy won't start, it just clicks
169,000 MILES • V6 • 4WD
NEVERSUMMER
I have a 1996 gmc jimmy SLS 4x4. The other day I went to start her up and it won't turn over or even try too. When I put the key in and turn it the battery turns on, lights work, radio, but when u turn the key to start it, it just clicks once then nothing. It won't try to crank itself over . I can hear the fuel pump priming the engine and the starter just clicks once and then that's it. Any suggestion on what it could be?
Jun 23, 2014 at 12:31 AM
  • 55,845 POSTS
This sounds like the battery is low on charge or needs to be replaced here is s guide that will show you how to load test the battery using the car.
And if bad this guide will show you how to replace the battery.
https://www.2carpros.com/articles/how-to-replace-a-car-battery
Cheers, Ken
Jan 2, 2018 at 9:57 AM
