Not cranking it just clicks loudly when trying to start
182,000 MILES • 3.8L • V6 • 4WD • MANUAL
PORTLANDJ42
I drove my vehicle listed above (JK) home from work the other morning and it was working fine when I parked it and shut it off. When I went out to go to work later in the day it wouldn't turn over and just had a loud clicking noise like the starter wanted to engage but nothing was turning. Am I dealing with a battery issue here or something worse?
Oct 5, 2020 at 5:02 AM
Good evening,
Could you upload a video of the noise when you try to start the car?
It could be the starter motor not working but need to be sure.
I attached a wiring diagram of the starting system in case we need to do some testing.
1. Disconnect and isolate negative battery cable.
2. Raise and support vehicle.
3. While supporting starter motor (1), remove two bolts (2) securing starter motor to transmission.
4. Lower starter motor far enough to access and remove nut (1) securing battery cable to starter solenoid B(+) terminal stud. Always support starter motor during this process. Do not let starter motor hang from wire harness.
5. Remove battery cable at starter.
6. Disconnect solenoid terminal wire harness connector from starter solenoid.
7. Remove starter motor.
Oct 5, 2020 at 8:26 AM
