Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Renault
Kangoo
Engine
Symptoms
Low Power
Jerky deceleration
2002 RENAULT KANGOO
139,000 MILES • 1.9L • 4 CYL • 2WD • MANUAL
BUSBY67Z
MEMBER
1 POST
Van accelerates okay, but engine is jerky when slowing down through the gears.
Aug 17, 2019 at 8:58 PM
Experienced Mechanic
Welcome to 2CarPros.
Can you explain exactly what is happening? When you decelerate, the engine isn't under a load, so I'm a bit confused.
Also, have you checked motor and trans mounts?
Aug 19, 2019 at 1:51 PM
Add image or video
Ask a new question
Engine won't start
