Codes P0101 and P0102, jerking when accelerating?
136,146 MILES • 2.2L • 4 CYL • 2WD • MANUAL
AZDANNO04
  • 376 POSTS
When taking off at a light and when shifting from first to second, even to third the vehicle jerks or acts like it does not have enough fuel. The check engine light was on but now it's off. Error codes P0101 and P0102 I replaced Mass Airflow sensor. But I need to check relay and fuses though.
Apr 15, 2023 at 2:51 AM
  • 55,616 POSTS
These codes can mean insufficient air traveling through your air filter. So, I would remove the air filter to see how dirty it is. Also check for leaks in the air intake tube between the MAF sensor and throttle body.
Apr 15, 2023 at 10:07 AM
AZDANNO04
  • 376 POSTS
I did purchase a K&N intake literally less than a month ago, but all is tightened. The only thing is the O2 sensors I need to replace since I had to get a new CAT because the old one where the flex neck of the pipe was cracked. I end up finding that they did sell just a flexing portion, but I already bought the other part. Which required me to replace the O2s as well. Which i am about to do. Will see if that's the issue.
Apr 16, 2023 at 3:05 PM
AZDANNO04
  • 376 POSTS
I noticed the gas cap isn’t as tight as it used to be and I know that will be pulling a code soon.
Apr 16, 2023 at 3:06 PM
  • 55,616 POSTS
When you replace the MAF sensor did you clear the codes?
Apr 17, 2023 at 3:16 AM
AZDANNO04
  • 376 POSTS
The check engine light went away but later on when it came back on. I did clear the code.
Apr 17, 2023 at 6:01 AM
AZDANNO04
  • 376 POSTS
Since I have a small leak in the transmission. It's the inner bell housing seal. I took it to a shop and either they pinched the seal putting it back in or the part was bad and wore out. I just need to do it myself than trusting a shop. To get to the Slave cylinder since its all one piece with the inner seal. And to see what shape the synchro or the gears are looking? Since I know I may had chipped a tooth on the fourth gear. Can you send me the steps for the tranny project I’m going to dive into? Especially the torque specs putting it back together, thank you.
Apr 18, 2023 at 12:01 AM
AZDANNO04
  • 376 POSTS
Didn’t know if you were able to help me replacing the seal on the slave cylinder?
Apr 21, 2023 at 11:36 AM
  • 55,616 POSTS
We only handle one problem per thread. Please post your new question here, you must be logged in.
Cheers, Ken
Apr 22, 2023 at 3:44 AM
