I ilike some advice, I have a engine check, took it to Auto Zone, put the engine analyzer, error code P0171, look it up on the WWW, it says that it couild be the MAF sensor, dirty or malfunction, my question is should I just put a new one on, or just clean it with a MAF sensor cleaner.
Causes
A code P0171 may mean that one or more of the following has happened:
The MAF (Mass Air Flow) Sensor is dirty or faulty. Note: The use of "oiled" air filters may cause the MAF to become dirty if the filter is over-oiled. There is also an issue with some vehicles where the MAF sensors leak the silicone potting material used to protect the circuitry.
There could be a vacuum leak downstream of the MAF sensor.
Causes
Mar 29, 2010 at 1:54 PM
