Jerking on accelerating
132,000 MILES • 6 CYL • 2WD • AUTOMATIC
HOBBS4J
Occasionally the car will jerk upon acceleration. The check engine light will flash and the traction control light will come on, when it happens.
The code reads low power to catalytic converter, could this really be the issue?
Jul 20, 2018 at 4:16 PM
DANNY L
  • 5,648 POSTS
Hello, I am Danny.
Just curious to know if you have access to the code numbers/written down? Usually a code P0421 or P0432 designates a Catalyst Efficiency Below Threshold. If the Converter is plugged that could cause the car to jerk/poor engine performance as well. If you could get back to us with the code information we would be happy to help you further. I have attached a few links for you to view. Hope this helps and thanks for using 2CarPros.
Danny-
https://www.2carpros.com/articles/bad-catalytic-converter-symptoms
https://www.2carpros.com/articles/how-to-test-a-catalytic-converter
Jul 20, 2018 at 7:13 PM
