Changed engine oil and overfilled it, my car now jerks sometimes?
226,565 MILES • 4.0L • V6 • 4WD • AUTOMATIC
ACRAWFORD2023
Me and my friend changed my engine oil but somehow overfilled it, my car now jerks sometimes trying to go into first, the RPMs will go to 3,000 before shifting sometimes. It does the same in reverse. When I go into second and third the shifts are smooth and the car drives fine while in higher gears. Could it be a problem with my spark plugs or coil packs?
Nov 10, 2022 at 8:59 PM
  • 55,710 POSTS
Yep, I think this can be a coincidence and when you are feeling it is an engine misfire. I would replace the spark plugs and coils.
Here are two videos to show you how:
https://youtu.be/tdnB4jaGSig
And this generic guide can help walk you through the job:
https://www.2carpros.com/articles/how-to-change-spark-plugs
Recommended Spark Plug
DENSO made .................... K20HR-U11
NGK made .................... LFR6C-11
Torque .................... 18 Nm (13 lb-ft)
Gap .................... 1.0 - 1.46 mm (0.039 - 0.047 in)
Nov 11, 2022 at 3:22 AM
