1995 Jeep YJ 5th gear
207,000 MILES • 6 CYL • 4WD • MANUAL
BUDDYT101
I have just started having a problem with 5 gear. When i shift into 5th the gears seem to have a problem going in and makes a noise, but while accelerating is fine. When I slow down it sounds like the transmission is grinding. 1st thru fourth are working great.I recently had the clutch replaced, but they did not replace the slave clutch.
Jul 30, 2009 at 5:33 AM
  • 31,937 POSTS
Hi there,
I feel that this is a internal problem with the 5th gear selector hub, as if the clutch was an issue you would have a problem with all gears,
mark (mhpautos)
Jul 30, 2009 at 5:37 PM
