1994 Jeep YJ Smog test
SODAASH
Engine Performance problem
1994 Jeep YJ 4 cyl Four Wheel Drive Manual 113k miles
hello
im tring to get my Jeep smog and it keeps failing NO (ppm) at 15mph... it passes at 25mph... it doesnt have a EGR ive already tried looking there but for some reason the 2.5L engine doesnt have one. i replaced spark plugs, wires, router and cap. An oil change has been done. Not sure what else i can do ive looked for vacum leaks but didnt find any... is there any thing else i can do to bring down the NO?
Oct 28, 2009 at 1:02 PM
  • 75,988 POSTS
Normally points to EGR valve
Could be caused by a bad three-way converter or a computer control system that remains in open loop meaning the computer throwing fuel at it all the time bcuz of a failed coolant temperature sensor. Is the engine getting hotter than usual if so it will raise the engine combustion chamber to form oxides of nitrogen
Oct 28, 2009 at 1:14 PM
SODAASH
Doesnt seem to be over heating... i just got the car this weekend but the gage never goes above 210 and the car doesnt seem like its real hot but like i said i just got the car so im not sure what the normal temp is suppose tobe.
Oct 28, 2009 at 1:40 PM
  • 75,988 POSTS
You're good on 210deg check the other stuffs I've mentioned and comeback with some results
Oct 28, 2009 at 1:43 PM
SODAASH
How can i check to see if the cat is working?
Oct 28, 2009 at 1:52 PM
  • 75,988 POSTS
Take it to a shop that does smog testing and have them sniff out the 5 gases with TAS machine this will tell if its doing its job/meaning scrubbing the gases.
Oct 28, 2009 at 3:27 PM
