1994 Jeep YJ leak
97,000 MILES • 4 CYL • 4WD • MANUAL
STEBROW
The seal at the rear of the transmission where the drive shaft enters is leaking. what is the seals name, and is it a relatively easy fix?
Keep in mind I bought it partly because of the ease of repair and replacement of parts. I have already replaced the starter, water pump, spark plugs w/wires, rotor, & distributer cap. I am only capable of replacing large parts, not small parts in large parts(transmission/transfer case gears).
Mar 22, 2009 at 11:28 AM
DOCFIXIT
  • 18,828 POSTS
Called trans output shaft seal. May have the tail shaft bushing worn . if D-shaft has play then tail shft needs to come off and replace bushing and seal.
Mar 25, 2009 at 6:52 AM
