1994 Jeep YJ Engine Knocking
121,000 MILES • 4 CYL • 4WD • MANUAL
RICH S
My wrangler has out of the blue started knocking. I have kept up on all routine maintenance since I have owned it for the last 10,000 miles. It is still running very strong and the performance does not feel hindered. I did notice that there seems to be water dripping out the exhaust and it is running a little hotter than normal. The radiator coils are falling off (flaking) so I bought a new one but have not installed it yet. However, I don't think this will fix the knocking. This is a project jeep and I eventually want to put a 350V8 in it but money is a little tight right now. Any suggestions?
-Rich
Dec 5, 2008 at 5:04 PM
MMPRINCE4000
  • 8,548 POSTS
Check the oil, if it is a chocolate color, you may have a head gasket failure. Coolant in the oil will wash the main bearings and cause a spun bearing and many other bad things
Perform a compression test to see if the headgasket is the problem.
Dec 6, 2008 at 2:41 AM
RICH S
I checked my oil and it was clean as a whistle and it has been 1,300 miles since I changed it. That is a good thing right? My next question is how much should I expect to pay for a compression test? Also, could it have anything to do with my exhaust?
Thanks,
-Rich
Dec 7, 2008 at 3:33 AM
RICH S
I was just tinkering and I noticed that the base of the fan where it goes into the engine has a slight wobble and the sound seems to be coming from there. It is a constant knock/grind sound even when I rev the engine up. What do you think?
Dec 7, 2008 at 3:50 AM
MMPRINCE4000
  • 8,548 POSTS
[quote:6cea714463="Rich S"]I was just tinkering and I noticed that the base of the fan where it goes into the engine has a slight wobble and the sound seems to be coming from there. It is a constant knock/grind sound even when I rev the engine up. What do you think?[/quote:6cea714463]
I think you are on to something. If it is not an engine knock (and the oil sounds good), then it could be an assy. like the fan, or bearing in a pulley.
Dec 9, 2008 at 4:07 AM
RICH S
Well I replaced the water pump, thermostat, and bought a used radiator that appears to be in good shape. The knock is completely gone and it actually sounds better than when I bought it! (After I had to return the first water pump since it has a reverse rotation.) However, it is over heating. There are no leaks, I sealed the gaskets, and the radiator is filled. Is it possible that I have bought a bad thermostat. I checked the upper hose and it seems to have pressure and is heating up along with the engine so I don't believe it is stuck shut. Any ideas?
-Rich
Dec 9, 2008 at 7:01 PM
MMPRINCE4000
  • 8,548 POSTS
If the hose to the thermostat does not get hot, then the thermostat is not opening. It may be a bad one, installed wrong, etc.
Dec 10, 2008 at 11:49 PM
