1994 Jeep YJ Clutch feels spongy
1994 JEEP WANGLER YJ
156,000 MILES • 6 CYL • 4WD • MANUAL
DEWEYMURRAY
When the clutch is depressed it seems like it is engaging farther and farther to the floor. There is not any griding of the gears. I checked the fluid and it is full. I noticed that when depressing the clutch pedal that there is space before the master cylinder shaft depresses. Is this a master cylinder problem or a clutch problem? I know that this is hard to explain without showing. I had a new clutch replaced 2 years ago when the transmission was worked on.
Sep 26, 2009 at 5:13 PM
Try bleeding it and then adjust the free play and pedal height
Sep 26, 2009 at 9:46 PM
