1993 Jeep YJ speedocable
91,000 MILES • 4 CYL • 4WD • MANUAL
JEEP FREAK
i just bought a 93 jeep and the speedometer does not work.i looked under the truck and checked to see if it is hooked up and it is. i am not very familar with this set up.any help would bee apperciated.if you know of any online manuals or skimatics avalible that would be great.tahnks.
Mar 14, 2009 at 10:17 AM
MECHCURT
  • 184 POSTS
Pull the cable under the vehicle loose and spin the cable end with your fingers. Have someone watch the speedo and they should see the gauge jump when you spin it.. Also these cables spin the ends quite frequently so check both ends if youi can. One other thing is on some of these older transfer cases there is a gear that mounts on the transfer case and then the speedo cable goes in make sure the gears work here also. Thanks and hope i helped some. Curt
Apr 25, 2009 at 3:13 AM
