1992 Jeep YJ Oil Pressure
1992 JEEP WANGLER YJ
100,000 MILES • 4 CYL • 4WD • MANUAL
ORLO73
I have a 1993 YJ Jeep Wrangler 2.5L. The oil pressure gauge would read at extreme pressure readings. I replaced the oil pressure sensor and the same problem is happening. What could this be?
Nov 19, 2008 at 11:45 AM
LERVIN
  • 15 POSTS
First you need to check your oil pressure with a mechanical gage. Harbor frieght tools has them at an ok price and the quality is ok too. Made by U.S. General I believe. If your oil pressure checks out to be truly high, then your probably looking at a new oil pump (the oil pressure regulator is part of the pump).
Nov 26, 2008 at 12:40 PM
