Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Jeep
Wangler YJ
Engine Cooling
Coolant Temperature Sensor
1991 Jeep YJ coolant temp sensor
1991 JEEP WANGLER YJ
95,000 MILES • 6 CYL • 4WD • MANUAL
JIMWATTS52
MEMBER
1 POST
what is the correct ohm/temp reading for the coolant temp sensor
Mar 8, 2009 at 1:22 PM
Experienced Mechanic
A typical coolant sensor, may have around 10,000 ohms resistance at 32 degrees F and drop to under 200 ohms when the engine is hot (200 degrees).
Mar 8, 2009 at 7:27 PM
🔧 Tools & Auto Repair Parts
Shop on Amazon →
Add image or video
Ask a new question
Engine won't start
Engine stalls while driving
