1990 Jeep YJ battery won't charge
EDOWNEY32
Electrical problem
1990 Jeep YJ 4 cyl Four Wheel Drive Manual
My battery won't charge in my jeep i have put in a new alt. and battery. What should i try next?
Nov 5, 2009 at 2:48 AM
  • 75,988 POSTS
Could be an open or short in the wiring to the ignition switch or the charge indicator.
Nov 5, 2009 at 2:56 AM
WILLIS2031
Could also be a faulty battery cable or cable connecter. I had the same problem on my 92 YJ and assumed first it was the battery and then the alternator, but it turned out I needed to replace the positive cable and negative connector. Check it out.
Feb 9, 2010 at 8:39 AM
