1988 Jeep YJ Stalling
SHWADLEY
  • 1988 JEEP WANGLER YJ
  • 6 CYL
  • 4WD
  • MANUAL
  • 96,000 MILES
My jeep has been stalling when coming to a stop both in gear and out of gear. It does it every once in a while. What could be the problem?
Wednesday, January 28th, 2009 AT 3:37 PM
Check the idle air control valve/motor/ISC, throttle position sensor, PCV and EGR valves
Wednesday, January 28th, 2009 AT 4:46 PM
HUNGRYEDDY
You jeep is an 88, carburated. You probably need to replace your carb, look into doing an mc2100 swap and nutter bypass, that fixed mine instantly and made it better
Monday, February 16th, 2009 AT 2:02 AM
