I have a 1988 Wrangler 2.5 4 cylinder, When its first cranked up it will run perfectly for aprox 2 miles then the engine dies almost to a stop but always picks back up. this goes on while at mid throttle but not when the pedal is on the mat. I replaced the fuel filter, cleaned out the fuel return line and install a fuel pressure gauge. The gauge stays at 14psi even while the engine is shutting down. What can I look for ? Thanks
Feb 14, 2010 at 5:22 AM
