2002 Jeep Wrangler Clutch Won't Drive
MRAEM
2002 Jeep Wrangler X, 6CYL MANUAL, 63,000 mi.
My Jeep hasn't shown any signs of having problems and was running fine on Friday and after sitting in the driveway over night, not driven, the next morning the clutch felt a little different than usual (harder than normal to press in) and makes a chattering sound when pressed all the way down. The other problem is that, the Jeep can shift into any gear without the clutch being pressed in at all and it won't drive at all. it will start and everything seems/sounds fine until the clutch is pressed down to the floor and makes a sound. I am in Germany right now and it will be much cheaper to order the parts from the states and take them to the mechanic but I have no clue what parts I would need to order and I would also like to have an idea of what the problem is so that I don't get overcharged for work not needed. Thanks in advance!
Apr 30, 2007 at 7:43 PM
2CARPRO JACK
  • 11,533 POSTS
Sounds like something may have broken in the pressure plate/ disc area.As long as the hydraulics are working, the mechanical parts are all that is left. I always recommend new clutch assemblies, not reman. Be sure that everything is replaced while in there, Pilot bearing/bushing, throw-out bearing, disc, press. plate
May 1, 2007 at 1:07 AM
Suggested Repair
If the clutch hydraulics are working, replace the clutch assembly with a new (not remanufactured) unit, including the disc, pressure plate, pilot bearing or bushing, and throw-out bearing.
Conversation Summary
A 2002 Jeep Wrangler with a manual transmission sat overnight, then the clutch became harder to press and chattered at the floor. It would start and shift into gear without the clutch but would not drive. The expert said the pressure plate or disc area may have failed and recommended a complete new clutch assembly, including the pilot bearing or bushing and throw-out bearing.
