1994 Jeep Wrangler Won't Reverse
JJ1201
I have a 1994 Jeep Wrangler with aprox 140, 000 miles I believe its a 4 liter.
I got this car from my mom, before i got it she had the u joints replaced. They put used ones in. When coming from a stop it feels like the rear end drops. I live in the snow. I pulled up in the driveway and pulled in crooked and tried to reverse but it wont move. I thought ok, im stuck in the snow but i wasnt, there was no snow around the tires. The rear tires dont move in 4wd and it wont reverse at all. whats wrong with my car? Is it bad?
Mar 1, 2007 at 12:58 PM
RETIREDAUTO
  • 46 POSTS
need more info. you stated in 4 wd won't move iether. dous drive shaft spins if not suspect t-case ? you mioght want to make sure u-joints arent bound or siezed(jack up and rotate drive shaft/push/pull up and down while holding yoke still let me know what u find out.
Mar 3, 2007 at 1:14 AM
MERLIN2021
  • 17,250 POSTS
NO ONE INSTALLS used ujoints they are 10.00 apiece! if the driveshaft fell out of the car it would roll! it sounds like because you went a bit sideways you now have a brake problem!
Mar 8, 2007 at 10:09 AM
Suggested Repair
Inspect the brakes for a locked or damaged brake after the Jeep was driven in sideways. A missing driveshaft would still allow the vehicle to roll, so do not assume failed U-joints caused the no-move condition. Also confirm whether the driveshaft turns and that the U-joints are not seized.
Conversation Summary
The owner of a 1994 Jeep Wrangler said used U-joints had been installed earlier. From a stop the rear felt like it dropped, and after pulling into a driveway crooked the Jeep would not reverse and the rear tires would not turn in 4WD. One reply suggested checking whether the driveshaft spins, inspecting the transfer case, and checking for seized U-joints. The expert said used U-joints are uncommon and inexpensive, a fallen driveshaft would still let the vehicle roll, and the sideways maneuver more likely caused a brake problem.
