Transmission Noise
JEEP WRANGLER
PENSTER
I have a 2002 Jeep Wrangler 4x4 automatic. There was an intermittent grinding noise in the differential area. The dealer repaired the transmission. I still heard the noise-faint but still present.
In addition, now when I press the brake pedal, there is a one time click heard inside the car from the gear shift/emergency brake area of the transmission.
What is wrong?
Sep 9, 2007 at 1:42 PM
LFRUCHEY
[quote:094422eb34="Penster"]I have a 2002 Jeep Wrangler 4x4 automatic. There was an intermittent grinding noise in the differential area. The dealer repaired the transmission. I still heard the noise-faint but still present.
What is wrong?[/quote:094422eb34]
Check to see if the bolts to the flywheel are tight.
Sep 9, 2007 at 2:05 PM
