1995 Jeep Wrangler Timing Chain Claim
CINDYFONTENOT81
I own a 1995 Jeep Wrangler with about 110,000 miles on it. I brought it to the shop to fix an oil leak on the main rear seal and also to change the valve cover gasket. After bringing it in, the mechanic told me that my timing chain was about to break and that it also needed changing. Someone told me that the timing chain was nowhere near the rear main seal or valve cover gasket and that this new, unexpected problem sounded "fishy". Is it possible to see the timing chain while making the other repairs or does this also seem odd to you? If it seems odd, what should I do? Also, approximately what should be the cost of these repairs?
Thanks,
Cindy Fontenot
May 28, 2006 at 4:25 PM
VANDRAGON
  • 298 POSTS
Cindy, go with your gut feeling. i am 51 years old and have only seen a timing chain break on a drag car. if your engine is a chrysler engine it has a timing chain at the front of the engine and can't be seen without removing pullies and belts. a bad timing chain sounds like the engine has gravel in the front of the engine, plus it has a rough idle.
May 29, 2006 at 3:04 AM
Suggested Repair
Do not approve a timing chain replacement based only on the rear main seal and valve cover work. The chain is at the front of the engine and cannot be seen without removing pulleys and belts. Seek a second opinion unless there is a gravel-like noise at the front and a rough idle.
Conversation Summary
The owner of a 1995 Jeep Wrangler was told the timing chain needed replacement while the shop was addressing a rear main seal oil leak and valve cover gasket. An expert said the chain is at the front and cannot be inspected during those repairs, and that a failing chain typically makes a gravel-like front noise and causes a rough idle. The owner was advised to trust that concern and not accept the unexpected recommendation without those symptoms.
