I drive a 02 Wrangler sport, inline 6, manual , 4 wheel high and low, with 37,000 and everything is stock. Just recently the rear end began to shudder at speeds between 60-70 and only when i accelerate. the wheel shakes just a little bit when this occurs. however i dont think its an alignment issue because when i let go of the wheel she stays straight. the tires are down pretty low under 1/8 inch. another problem i have with the jeep is there is a very small oil leak where the transmission starts right past the oil pan. it only leaks for 5 minutes after i turn it off, and only drips 5-10 drops. the oil gauge stays between 40-60 however i notice it likes to stay more towards the 60 side. i checked the oil and it is in the right limits. someone told me the shuddering could be a bearing going out but any help you guys had would be appreciated.
May 16, 2007 at 2:05 PM
