the outside handle on the 04 wrangler is loose. how do you remove door covering so i can fix the door handle?
Jan 8, 2007 at 10:52 AM
MWHITNEY
MEMBER
there is a screw in the pull handle in side the door. then at the top of the door there is a pastic piece that pulls off then a screw in the handle housing . once all the screw are removed the the door needs a good pull at the bottom and the rest of the holder will pop out.
Jan 16, 2007 at 12:19 PM
