2000 Jeep Wrangler Partial Blower Speeds
RBSDD
2000 jeep wrangler, 78k mi., 4cyl.; my a/c stopped blowing cold although my compressor is cycling on and off. shortly after this happened my blower stopped working. i replaced the fuse in the glove box and now have air flow on 2 of 4 speed settings( the lower 2 settings). what is the problem
Sep 20, 2007 at 4:07 PM
  • 75,988 POSTS
[quote:a438012f25="rbsdd"]2000 jeep wrangler, 78k mi., 4cyl.; my a/c stopped blowing cold although my compressor is cycling on and off. shortly after this happened my blower stopped working. i replaced the fuse in the glove box and now have air flow on 2 of 4 speed settings( the lower 2 settings). what is the problem[/quote:a438012f25]
Its either the control switch or the blower resistor.
But I'll go for the Blower resistor 1st its on the HVAC harness
Sep 20, 2007 at 4:45 PM
Suggested Repair
Check the blower resistor on the HVAC harness first. If that is not the cause, inspect the blower control switch.
Conversation Summary
A 2000 Jeep Wrangler lost cold A/C while the compressor still cycled, then the blower stopped. After replacing the glove-box fuse, only the two lower blower speeds worked. The expert said the cause is either the control switch or the blower resistor and recommended checking the blower resistor on the HVAC harness first.
