Air conditioner only works on full speed
VINNY CASH
2004 Jeep Wrangler SE 2.4L 4cyl 23,000 miles, My Jeep's air conditioner will only run on full speed. There are only 4 speeds and it will only kick on when the knob is turned to the fourth blower speed. When turned to a lower speed it's very quiet and barely dribbles out almost as if it's not even on. When on the highest speed the air is cold but it's much louder than usual. The sound seems to be coming through the vents and its like a loud hum. It seems to be condensating more too but I figured that was because it was always runing at full speed. Could it be the control in the dash?
Aug 11, 2007 at 4:57 PM
2CARPRO JACK
  • 11,533 POSTS
Could be.... most likely the fan speed resistor. Should be in the HVAC plenum near the blower motor. Follow the wires from the blower, should go to the resistor or fan speed controller.
Aug 12, 2007 at 1:59 AM
