'93 jeep wrangler with clutch issues
MCGRATH147
i have a '93 jeep wrangler 4.0L 5spd. i have performed a very novice frame-off restoration over the last couple years. i put a 3.5" suspension lift and a 2" body lift on it. the suspension lift actually required the transmission be lowered about two inches, as well. my master clutch cylinder hose is broken and i need to replace it. an OEM replacement is about $90, and seems rather rediculous, especially since i don't know if it is even long enough due to my modifications. my question is...is there any kind of hose that i can use that would replace it safely and cheaply? or, if i do get the oem replacement, will it be long enough?
Dec 19, 2006 at 12:44 PM
GOFASTER21
  • 6 POSTS
That must be for a hard line correct?
Clutch line = brake line, so you can make your own with brake line stuff, either braided or hardline which may or may not be cheaper, something to look into
Dec 20, 2006 at 4:05 AM
