2006 Jeep Wrangler flashers
97,000 MILES • 6 CYL • 4WD • AUTOMATIC
OKAY
where is the flasher on a right hand drive i cant find it i would think it would be in the same place just backwards but i dont know where that would be i use it on a mail route I checked the bulbs and they work a person at auto store said it was the flasher so i bought it but cant find it
Aug 30, 2010 at 9:15 AM
BLUELIGHTNIN6
  • 16,542 POSTS
it uses a combination flasher so if hazards work but signals don't than flasher is OK. flasher is located to the back of the multi-function switch housing on the top of the steering column
Aug 30, 2010 at 10:47 AM
OKAY
[quote:ee95dfce60="bluelightnin6"]it uses a combination flasher so if hazards work but signals don't than flasher is OK. flasher is located to the back of the multi-function switch housing on the top of the steering column[/quote:ee95dfce60] I know how to use the flasher it does not work and neither do my blinkers the guy at the auto shop said it was the flasher. I bought the thing called a flasher it looks like a large fuse. i need to know where the fuse is
Aug 30, 2010 at 11:04 AM
BLUELIGHTNIN6
  • 16,542 POSTS
?? ..i was not explaing how to use the hazard lights..i was explaining to you where the combination flasher (the "fuse" ) is..
Aug 30, 2010 at 11:06 AM
OKAY
[quote="bluelightnin6"]?? ..i was not explaing how to use the hazard lights..i was explaining to you where the combination flasher (the "fuse" ) is..[/quote still looking will let you know thank you
Aug 30, 2010 at 11:58 AM
BLUELIGHTNIN6
  • 16,542 POSTS
remove shroud around signal and wiper switch (aka multi function switch),and it is between them
Aug 30, 2010 at 12:11 PM
